Lamberto_1975
- 27 Marzo 2019
- PR
- Stonic
Non so dirti io ho la Style. Ma nel manuale che credo sia unico per tutti gli allestimenti non fa cenno ad altro.
... sni... probabilmente avevano rabboccato le gomme con dell'aria sporca.Allora mi domando se dopo appena 400 km possa essere calata già la pressione.
- 79% azoto;
- 20% ossigeno;
- <1% anidride carbonica;
- percentuali trascurabili di altri gas (fra i quali gas nobili, altri gas, particelle e vapori vari in particolare d'acqua).
Resetting Your Tire Pressure Light
After you properly inflate your tires, the tire pressure light should go off on its own. If it remains on, there are a few actions you can take:
- Drive at or above 50 mph for 10 minutes. This can cause your sensor to reset the next time you turn on the car.
- With the vehicle off, turn the key to the “On” position, but don’t start the car. Hold the TPMS reset button until the tire pressure light blinks three times, then release it. Start the car and wait 20 minutes for the sensor to refresh. The tire pressure monitor reset button is usually located beneath the steering wheel. If you can’t find it, check the user’s manual.
- Inflate all tires to 3 PSI over their recommended amount, then deflate them completely. Be sure to include the spare tire, as it may have a sensor as well. Once they’re all deflated, re-inflate to the recommended tire pressure.
- With the vehicle off, disconnect the positive battery cable with a wrench. Turn the car on and honk the horn for about three seconds. This will discharge any power still stored in the vehicle. Then reconnect the battery.
Nel manuale ricordo di aver letto che segnala solo quando la pressione e inferiore a quella settata.
